I have tested with Grafana11.4.1and11.6.1 -
I’m trying to run multiple Grafana setups on one Kubernetes cluster. Each setup has two replicas. -
I’m using HELM chart. My HA setup:
extraExposePorts:
- name: "grafana-alert"
port: 9094
targetPort: 9094
grafana.ini:
unified_alerting:
enabled: true
ha_listen_address: "${grafana_pod_ip}:9094"
ha_advertise_address: "${grafana_pod_ip}:9094"
ha_peers: "$CLUSTER_NAME:9094"
serviceMonitor:
enabled: true
Each grafana setup is in different namespace.
What happened?
Alertmanager is connecting to ALL alertmanagers on Kubernetes cluster. If I create 20 or 30 Grafana setups, they all connect to each other. ( 20 setups * 2 replicas = 40 alertmanager peers ) WHY? How to prevent this?
Seams because of this mesh clustering alerts are delayed to deliver. -
Each grafana setup connect ONLY to it’s grafana alertmanagers. -
Not shure which part. -
If I delete deployment and re-create it it has only replica in alertmanager peers, but in few minutes to alert manager all grafana setups are introduced. Log example:
logger=ngalert.multiorg.alertmanager component=clustering t=2025-05-08T09:08:34.884518081Z level=debug memberlist="2025/05/08 09:08:34 [DEBUG] memberlist: Stream connection from=10.15.99.117:41146\n"
logger=ngalert.multiorg.alertmanager component=clustering t=2025-05-08T09:08:34.885068991Z level=debug received=NotifyJoin node=01JTJB58VHEEKEHK1AZCC9C7R5 addr=10.15.118.205:9094
logger=ngalert.multiorg.alertmanager component=clustering t=2025-05-08T09:08:34.885105163Z level=debug received=NotifyJoin node=01JTJRRZ26HXEJCW0S28PMK34G addr=10.15.184.150:9094
logger=ngalert.multiorg.alertmanager component=clustering t=2025-05-08T09:08:34.885126984Z level=debug received=NotifyJoin node=01JTJPQQMBXGB4AMP3449S5ZF7 addr=10.15.106.212:9094
logger=ngalert.multiorg.alertmanager component=clustering t=2025-05-08T09:08:34.885145705Z level=debug received=NotifyJoin node=01JTJB43D13BVHKJTDM6A16S2J addr=10.15.31.177:9094
logger=ngalert.multiorg.alertmanager component=clustering t=2025-05-08T09:08:34.885163786Z level=debug received=NotifyJoin node=01JTJWW3VM6N1TQ6YYBCBMASGV addr=10.15.129.87:9094
- Did you follow any online instructions? If so, what is the URL?
I’m confused how Grafana Alertmanager is discovering peers. I have done some experiments disabling or enabling things, but didn’t understood mechanics behind it. I’m seeking for good explanation how that discovery works and how to prevent it ![]()
