10.1.0 -
grafana alert with image -
i already install renderer plugins
and I click panel edit and click alert to create alert rules -
What happened?
there is my alert message
I clicked on the ‘Edit’ button in the ‘Rules’ panel on my dashboard, and then went to the ‘Alert’ page to add alerts. After adding alerts, when testing the alarms, I receive notifications like this:
However, there are a few issues:
I want my alert messages can be shorter. I only need the “instance name”、“what happened (e.g., High CPU usage detected)” and the panel URL or panel image.
Regardless of which host triggers the alarm, when I click on the panel URL, it always leads to the same host’s panel. How can I ensure that the panel corresponds to the correct host? Did I select the wrong panel when adding the alert?
please help…thanks
