A - Version - 9.4.7 -
A - Grafana Alert Manager Webhook Configuration using mTLS. -
A - Using Grafana Alert Manager -
What happened?
A - Grafana Alert Manager does not support mTLS configuration. -
A - Support for mTLS configuration or some other workaround. My Webhook destination is mTLS enabled and hence it cannot be called without client certs. There is no way of configuring Client certs for Grafana Webhook Integration. Is there some workaround with which this can be achieved? -
A - NA -
A - NA -
A - NA
