Grafana-agent-0.37.3-1 -
Running the Grafana agent as a service. -
Running the installation script generated as part of the Grafana cloud agent tutorial -
What happened?
After installing the grafana agent, the service failed to start with the following error
Nov 23 14:01:10 fedora-8gb-ash-1 grafana-agent[1692]: ts=2023-11-23T14:01:10.597513115Z caller=main.go:71 level=info boringcryptoenabled=false
Nov 23 14:01:10 fedora-8gb-ash-1 grafana-agent[1692]: ts=2023-11-23T14:01:10.597759527Z caller=main.go:74 level=error msg="error creating the agent server entrypoint" err="creating gRPC listener: listen tcp 127.0.0.1:9091: bind: address already in use"
Nov 23 14:01:10 fedora-8gb-ash-1 systemd[1]: grafana-agent.service: Main process exited, code=exited, status=1/FAILURE
Nov 23 14:01:10 fedora-8gb-ash-1 systemd[1]: grafana-agent.service: Failed with result 'exit-code'.
Nov 23 14:01:10 fedora-8gb-ash-1 systemd[1]: grafana-agent.service: Scheduled restart job, restart counter is at 5.
Nov 23 14:01:10 fedora-8gb-ash-1 systemd[1]: grafana-agent.service: Start request repeated too quickly.
Nov 23 14:01:10 fedora-8gb-ash-1 systemd[1]: Failed to start grafana-agent.service - Monitoring system and forwarder.
The Grafana agent to start without throwing an error
- Did you follow any online instructions? If so, what is the URL?
Only instructions followed were the Grafana Agent installation guide on my grafana cloud instance
