blauter
September 21, 2021, 3:47pm
1
I am testing Grafana 8.1.2 with new alerting system enabled and looking to customize the subject of the email. I disabled alert grouping so each match is triggering separate alert but when doing this, all tag values are appended to email subject.
I looked into templates but seems like I can only customize email contents.
I am also looking to be able to customize the alert email subject. Were you ever able to resolve this?
thanks
support for this is coming soon!
grafana:main ← grafana:jacobsonmt/49716_add_subject_template_in_email_notifier
opened 11:07PM - 26 May 22 UTC
**What this PR does / why we need it**:
This PR adds a new templated config t… o the email notifier for the subject of the email. This is part of a larger standardization of templated message fields in notifiers: https://github.com/grafana/grafana/issues/49716
**Which issue(s) this PR fixes**:
Partial: https://github.com/grafana/grafana/issues/49716
**Special notes for your reviewer**:
New Field:
Templated Subject:
<img src="https://user-images.githubusercontent.com/8484471/170592617-a3345fdb-91d8-4c6c-9584-de88ef6b22b7.png" width="500" height="400">
