Hi, anyone else has issue with Graph (old) and Time series?
Then reported values is 1 then on Graph (old) value is displayed correctly, after upgrade to 8.0, updated few graphs to Time series and visualization is strange then value is 1
Hi @progparoles
Can you share your dashboard json? And which exact version are you running? Couldn’t quite replicate this on 8.0.2
I had the same problem using 8.0.2 on Windows, downgraded to 7.5.8.
favor:
could either of you try to reproduce this on play.grafana.org?
