I have a question regarding global variables.
I’m using Postgresql, in my query I have 2 returns, the first an alias another a code, I need the alias to be visualized, in the list that is on the dashboard more when I point this variable in my panel the code that is returned in the query that will be used, I believe this replacement is done with regex
Hi @dudaarch,
Welcome to the
community support forums !!
I am not certain that I understand your question correctly. But to best understanding, your SQL query gives you to outupt as the final result i.e.
LJFF 10
F8033…C_20
And you are using one of these as an alias. If this is correct then, yes you can use regex to limit/hide your results that you do not want to view for e.g.
use something like, if you want to hide:
/.LJFF*/ => to hide LJFF 10
or the other way for F8033…C_20
I hope this helps.
