v10.3.1
- What are you trying to achieve?
I am trying to use the global user variable to get the logged in user using ${__user.login} but the value of the variable is not populated
I used
SELECT '${__user.login}' as test
and get this as the resulting table:
test
${__user.login}
I tried other global variables like
SELECT '$__timezone' as test
and these work fine.
There are no obvious error message when using $__user.
