v9.0.1
I am using $__user.login in a dashboard to control visibility.
Now I have updated a second server with identical
Postgres 12
Identical database (copied from other server)
I can login and see my username when clicking the user icon.
Data source: postgres
But the following query remains empty on the 2nd server:
SELECT '${__user.login}' AS user
Nothing logged at that point in time.
Upate: on dashboard load
Any hints?
Check here, user could remove this then ${__user.login}
might be empty
Thank you for the hint.
I am using my users (2 admins and 1 standard) All 3 user fields (name, email, username) are filled in.
Identical on both servers.
Can you spin up a separate latest grafana version and see if issue might have been fixed
With latest Grafana=v10.3.1 (OSS) I cannot reproduce this an more.
Clearly, this is the standard solution after reboot or things like that.
But it helped in my case.
Thank you!
