give me an example query sql for panel G3 Gauge table
Thanks
Thanks
Hey.
First of all, please close the similar/duplicate 2 topics regarding d3 gauge error. You cannot just create new topics slightly the same. It’s better if you edit an existing topic and trying to explain the problem/description more thorough.
In order for anyone to help you. Please include a link to the plugin you’re to use/are problematic (are you talking about D3 or G3? Then include the query in detail that you’re using.
Please refer to Using Grafana's Query Inspector to troubleshoot issues
Marcus
xhrStatus:"complete"
request:Object
method:"POST"
url:"api/tsdb/query"
data:Object
to:"1547265641000"
queries:Array[1]
0:Object
refId:"A"
intervalMs:21600000
maxDataPoints:1334
datasourceId:7
rawSql:"SELECT temperature as value, temperature as metric FROM tbl_grafana "
format:"table"
response:Object
results:Object
A:Object
refId:"A"
meta:Object
rowCount:3
sql:"SELECT temperature as value, temperature as metric FROM tbl_grafana "
series:null
tables:Array[1]
0:Object
columns:Array[2]
0:Object
text:"value"
1:Object
text:"metric"
rows:Array[3]
0:Array[99,99]
1:Array[76,76]
2:Array[34,34]
I moved your answer here. Did you noticed that you posted your response in the link I referenced??? Why did you do that?
What grafana version are you using?
What errors do you get?
Marcus
Thanks.
Are you sure that you should use Format as Table and not Format as Time series? I have not used this plugin, but looking at its github repo it says
Data operator same as SingleStat panel (avg, sum, current, etc)
Which in my head sounds like you should use a proper time series query instead of a table query.
Marcus
Seems here you need to select only one value? Like SELECT TOP 1 ...
You may want to create an issue over at the plugin github repo for detailed questions?
Marcus
Seems like mysql don’t support SELECT TOP 1. You’ll need to remove TOP 1 and add LIMIT 1 between your WHERE and ORDER BY clause.
Marcus
