I have a MySQL replica syncing data from a MySQL master. Most of the time the replica is up to date (sync latency = 0 seconds), but sometimes the replica falls behind master by couple of seconds. I want to graph this sync latency.
I get the data from CheckMK data source. The data source works, the Query Inspector sees this series of 60 values (1 hour worth of data sampled every minute):
{"result": {"step": 60, "start_time": 1605594720, "end_time": 1605598380, "curves": [{"color": "#ffb080", "title": "Sync latency", "line_type": "area", "rrddata": [0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 1.63333, 0.666667, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0]}]}, "result_code": 0}
For these values Graphana shows this graph:
Where are the zeros? Why doesn’t Graphana show them as aline on x axis? Even worse, then I have a time period with zeros only (slave was up-to-date all the time) the graph shows “No data”.
How can I configure the graph to show the zeros?
Thank you,
Regards,
Oskar
