The Problem:
I have an API query which returns following JSON:
"ver": 1745357818,
"list": [
"id": "111",
"inner_list": [
"inner_id": "222"
and i want to use “id”, “inner_id” and “ver” from that JSON in different text panels across dashboard. I want to have only one query for all dashboard panels.
What I’ve tried:
I’ve tried to create a master variable “MasterVar” like this (i use inline source instead of an actual API query just to simplify):
and use it directly in the text panels for display at least “ver” like this: ${MasterVar.ver} or ${MasterVar:ver} or ${MasterVar}.“ver” or in other hundred variants, but as a result i only had same original json:
sometimes with some minor modifications. I didin’t even try to display nested values like “id” and “inner_id” since i didn’t succeed with “ver”.
I’ve tried to make other variables and parse “MasterVar” in these variables but didn’t succeed as well and get empty result
I think i didn’t get something significant because this process of getting multiple variables from one query should be basic and simple. I would appreciate any help.
2 values from one variable is doable by using key/value
but 3 is also possible but it depends. Will you will be displaying the list of these values like so?
Thanks for your answer! But seems like i didn’t get it. I need way more that 3 values in original JSON, something around 20. And Is it necessary to use Business Text plugin, because i’d like to use only standart elements? Now i only have ordinary text panel and i can use only dashboard variables here.
It’s seems strange for me to presume that grafana doesen’t have standart mechanism to minimize amount of queries, maybe i still miss something here.
I am not sure you can reference values via ${Master:ver}
Me too, because i already tried it as i said in my initial post.
Anyway, thanks for your help @yosiasz i am really appreciate it! I still have two more questions below, please, consider to answer them.
I installed Business Text plugin, but still cant’t get result from your screenshot.
Here is what i got in normal view mode(empty cells):
And in table view mode (all data is parsed correctly):
Can you please show me full settings from your screenshot?
I still can’t figure out how using Business Text plugin can help me to solve problem from initial post. Can you please eleborate it to me?
This should help
Since it is html you can add click events to capture values from your data to use as you wish
