Getting K6 to complete all initiated tests
I’m trying to interpret the results from a test session and it would appear that my api backend received more requests than indicated via the iterations metric. My test contains a large number of VU’s (1000), I’m assuming that iterations may not capture the total number of call made to the backend as a VU will be terminated once my test duration is complete (i.e. there could be many VU’s that have made a request but have not completed, and as such are not included in the stats).
Is this the case?
If so, is there a way to ensure that all VU’s complete gracefully so that I can make a valid reconciliation between API logs and K6 stats?
As an example, I configured K6 with the following:
export let options = {
  // simulate rampup of traffic from 1 to 1000 users over 30 secs.
  stages: [
    {duration: '30s', target: 1000},
    {duration: '30s', target: 0},
My backend logs tell me that 9615 requests where made, yet K6 stats tell me the following:
execution: local
     output: -
     script: ./test/load_test/k6test.js
    duration: -,  iterations: -
         vus: 1, max: 1000
    done [==========================================================] 1m30s / 1m30s
    ✓ post successful
    202........................: 9170    101.888701/s
    Initiated..................: 10170   112.999791/s
    checks.....................: 100.00% ✓ 9170   ✗ 0
    data_received..............: 7.8 MB  86 kB/s
    data_sent..................: 11 MB   122 kB/s
    http_req_blocked...........: avg=24.69ms  min=0s      med=1µs      max=5.65s  p(90)=1µs      p(95)=60.6ms
    http_req_connecting........: avg=9.84ms   min=0s      med=0s       max=1.57s  p(90)=0s       p(95)=16.54ms
    http_req_duration..........: avg=1.53s    min=92.77ms med=206.69ms max=46.99s p(90)=3s       p(95)=11.29s
    http_req_receiving.........: avg=159.42ms min=60µs    med=344µs    max=33.13s p(90)=81.21ms  p(95)=163.99ms
    http_req_sending...........: avg=40.38ms  min=53µs    med=241µs    max=1.48s  p(90)=111.94ms p(95)=347.02ms
    http_req_tls_handshaking...: avg=11.18ms  min=0s      med=0s       max=4.51s  p(90)=0s       p(95)=41.57ms
    http_req_waiting...........: avg=1.33s    min=0s      med=198.19ms max=34.64s p(90)=2.86s    p(95)=10.29s
    http_reqs..................: 9170    101.888701/s
    iteration_duration.........: avg=1.55s    min=93.31ms med=213.34ms max=46.99s p(90)=3.25s    p(95)=11.3s
    iterations.................: 9170    101.888701/s
    vus........................: 0       min=0    max=998
    vus_max....................: 1000    min=1000 max=1000
So I can see that 10170 requests were ‘initiated’ (that is, they got as far as the call to the test function), 9615 requests arrived at the API (so 10170 - 9615 = 555 initiated tests did not make the request)
Is it possible to ensure that all VU’s complete gracefully and add their stats / metrics before they are terminated?
Hi there,
unfortunately, this is a known issue in k6 (see #879) which will be resolved with the refactor work currently in progress in #1007. See the gracefulStop and gracefulRampDown executor options. You can follow those issues for updates.
In the meantime, you can try setting a fixed amount of iterations or duration for the test with the k6 run --iterations or --duration flags or respective environment variables with a previously known value to allow for all requests to complete successfully. See the documentation for details.
Hope this helps,
Ivan
Thanks Ivan, muh appreciated!
The just-released k6 v0.27.0 includes gracefulStop and gracefulRampDown:
