Getting gateway timeout errors
we are using postgresql as datasource, in dashboard we are using base panel method which is built of seven queries. but whenever we are trying to fetch the data for 3 or more than 3 days we are getting gateway timeout.
    we are using AWS Managed Grafana version 8.4.7
    trying to build dashboard in grafana out of data stored in postgresql data
    Using custom postgres queries
  • What happened?
    Getting 504 gateway time out while trying to pull data for last 7 days but we are able to fetch data for other timeframes like 5min,15min,1 day. Not able to fetch the data for more than one day
504 Gateway Time-out
    Expect to populate data
    we dont have any access to grafana backend server as it is aws managed grafana
    no
