Getting error with prometheus.exporter.mysql "integrations_mysqld_exporter" #grafana-alloy
Hi Grafana team im a newbie and i want to scrape data from a digital ocean mysql database using Grafana Alloy, i get the following error and im confused on what im doing wrong:
Error: /etc/alloy/config.alloy:66:1: Failed to build component: decoding configuration: invalid value / unknown config name: true
prometheus.exporter.mysql "integrations_mysqld_exporter" {
_^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
 data_source_name = local.file.mysql_secret.content
|_^
this is my config file:
prometheus.exporter.self "alloy_check" { }
discovery.relabel "alloy_check" {
  targets = prometheus.exporter.self.alloy_check.targets
  rule {
    target_label = "instance"
  rule {
    target_label = "alloy_hostname"
  rule {
    target_label = "job"
    replacement  = "integrations/alloy-check"
prometheus.scrape "alloy_check" {
  targets    = discovery.relabel.alloy_check.output
  forward_to = [prometheus.relabel.alloy_check.receiver]
  scrape_interval = "60s"
prometheus.relabel "alloy_check" {
  rule {
    source_labels = ["__name__"]
    regex         = "(prometheus_target_sync_length_seconds_sum|prometheus_target_scrapes_.*|prometheus_target_interval.*|prometheus_sd_discovered_targets|alloy_build.*|prometheus_remote_write_wal_samples_appended_total|process_start_time_seconds)"
    action        = "keep"
prometheus.remote_write "metrics_service" {
  endpoint {
    url = "https://prometheus-prod-13-prod-us-east-0.grafana.net/api/prom/push"
    basic_auth {
      username = "1649549"
      password = "glc_eyJvIjoiMTE1NzI1NSIsIm4iOiJzdGFjay05NjY5MTgtaW50ZWdyYXRpb24tbXlzcWwtY29sbGVjdG9yIiwiayI6Imp4V3doN2ozV3ZuMTcwSzdMWjUwOUh6MSIsIm0iOnsiciI6InByb2QtdXMtZWFzdC0wIn19"
loki.write "grafana_cloud_loki" {
  endpoint {
    url = "https://logs-prod-006.grafana.net/loki/api/v1/push"
    basic_auth {
      username = "924698"
local.file "mysql_secret" {
  filename = "/var/lib/alloy/mysql-secret"
  is_secret = true
discovery.relabel "integrations_mysqld_exporter" {
  targets = prometheus.exporter.mysql.integrations_mysqld_exporter.targets
  rule {
    replacement  = "integrations/mysql"
  rule {
    replacement  = "DO_AFROAI_DB"
prometheus.relabel "integrations_mysqld_exporter" {
        rule {
    action = "keep"
    regex  = "up|instance:mysql_heartbeat_lag_seconds|instance:mysql_slave_lag_seconds|mysql_global_status_aborted_clients|mysql_global_status_aborted_connects|mysql_global_status_buffer_pool_pages|mysql_global_status_bytes_received|mysql_global_status_bytes_sent|mysql_global_status_commands_total|mysql_global_status_created_tmp_disk_tables|mysql_global_status_created_tmp_files|mysql_global_status_created_tmp_tables|mysql_global_status_handlers_total|mysql_global_status_innodb_log_waits|mysql_global_status_innodb_mem_adaptive_hash|mysql_global_status_innodb_mem_dictionary|mysql_global_status_innodb_num_open_files|mysql_global_status_innodb_page_size|mysql_global_status_max_used_connections|mysql_global_status_open_files|mysql_global_status_open_table_definitions|mysql_global_status_open_tables|mysql_global_status_opened_files|mysql_global_status_opened_table_definitions|mysql_global_status_opened_tables|mysql_global_status_qcache_free_memory|mysql_global_status_qcache_hits|mysql_global_status_qcache_inserts|mysql_global_status_qcache_lowmem_prunes|mysql_global_status_qcache_not_cached|mysql_global_status_qcache_queries_in_cache|mysql_global_status_queries|mysql_global_status_questions|mysql_global_status_select_full_join|mysql_global_status_select_full_range_join|mysql_global_status_select_range|mysql_global_status_select_range_check|mysql_global_status_select_scan|mysql_global_status_slow_queries|mysql_global_status_sort_merge_passes|mysql_global_status_sort_range|mysql_global_status_sort_rows|mysql_global_status_sort_scan|mysql_global_status_table_locks_immediate|mysql_global_status_table_locks_waited|mysql_global_status_table_open_cache_hits|mysql_global_status_table_open_cache_misses|mysql_global_status_table_open_cache_overflows|mysql_global_status_threads_cached|mysql_global_status_threads_connected|mysql_global_status_threads_created|mysql_global_status_threads_running|mysql_global_status_uptime|mysql_global_status_wsrep_local_recv_queue|mysql_global_status_wsrep_local_state|mysql_global_status_wsrep_ready|mysql_global_variables_innodb_additional_mem_pool_size|mysql_global_variables_innodb_buffer_pool_size|mysql_global_variables_innodb_log_buffer_size|mysql_global_variables_key_buffer_size|mysql_global_variables_max_connections|mysql_global_variables_open_files_limit|mysql_global_variables_query_cache_size|mysql_global_variables_table_definition_cache|mysql_global_variables_table_open_cache|mysql_global_variables_thread_cache_size|mysql_global_variables_tokudb_cache_size|mysql_global_variables_wsrep_desync|mysql_heartbeat_now_timestamp_seconds|mysql_heartbeat_stored_timestamp_seconds|mysql_info_schema_processlist_threads|mysql_slave_status_seconds_behind_master|mysql_slave_status_slave_io_running|mysql_slave_status_slave_sql_running|mysql_slave_status_sql_delay|mysql_up"
prometheus.scrape "integrations_mysqld_exporter" {
  targets    = discovery.relabel.integrations_mysqld_exporter.output
  forward_to = [prometheus.relabel.integrations_mysqld_exporter.receiver]
  job_name   = "integrations/mysqld_exporter"
local.file_match "logs_integrations_mysql" {
  path_targets = [{
    __address__ = "localhost",
    __path__    = "/var/log/mysql/*.log",
    instance    = "DO_AFROAI_DB",
    job         = "integrations/mysql",
loki.process "logs_integrations_mysql" {
  forward_to = [loki.write.grafana_cloud_loki.receiver]
  stage.regex {
    expression = "(?P<timestamp>.+) (?P<thread>[\\d]+) \\[(?P<label>.+?)\\]( \\[(?P<err_code>.+?)\\] \\[(?P<subsystem>.+?)\\])? (?P<msg>.+)"
  stage.labels {
    values = {
      err_code  = null,
      level     = "label",
      subsystem = null,
  stage.drop {
    drop_counter_reason = "drop empty lines"
    expression          = "^ *$"
loki.source.file "logs_integrations_mysql" {
  targets    = local.file_match.logs_integrations_mysql.targets
  forward_to = [loki.process.logs_integrations_mysql.receiver]
