Getting error in K6 get method (Unexpected token)
I am new to load testing and I used the very basic example code from the K6 and getting following error.
This is the code :
import http from 'k6/http';
import { sleep } from 'k6';
export default function() {
  http.get('http://190.102.253.223:30500/30');
  sleep(1);
this is the error :
http.get(‘http://190.102.253.223:30500/30’);
5 | sleep(1);
6 |
| ^ at <internal/k6/compiler/lib/babel.min.js>:2:28542(109)
I want to send a parameter 30 in the GET method and it will return JSON output.
It works fine with curl
curl http://190.102.253.223:30500/30
What can I do to solve this issue
thank you in advance.
Hi @menukaperera,
Welcome to the community forums! :wave:
It seems that the bracket from the default function is missed.
The code below should work
  sleep(1);
Let me know if that helps,
Cheers!
