Getting an Organization Properties by Org ID/Name
2024-03-10 19:10:05 INF Version=10.0.0
2024-03-10 19:10:05 INF Commit=81d85ce802
Let’s say I want to list all the properties of all orgs in my grafana instance, as far as I can tell the only way to do this is to invoke the following calls for each organization in question.
curl -X GET ‘http://localhost:3000/api/user/using/55
to switch the user context to the given Org.
curl -X GET http://localhost:3000/api/org
to return the orgs properties. This seems really overly complicated as opposed to say as a grafana admin being able to just called.
curl -X GET ‘http://localhost:3000/api/org/55/properties
Is there some undocumented endpoint I’m not aware of is this the pattern?
For every change I need to do, or say to do a listing, I essentially have to:
  1. Change Org,
  2. Read/Write Properties
  3. Restore Org
Have a cli tool to exposed the Orgs and their properties allowing the user to update the properties easily from the CLI.
  • What happened?
The exposed API seems overly complex to use.
A simpler endpoint to invoke to read/write properties for a given Org when logged in as a grafana admin.
NA
Nope
NA
