Hi! I want to take an array of values depending on the current state.
example of variables:
test1 = 1,2,3
test2 = 4,5,6
test3 = PROD : $test1, STG : $test2
is it possible to get it from test3. something like ${test3:value[2]}?
test1 = 1,2,3
test2 = 4,5,6
thanks for the answer. But this is not quite the same…
in fact, I need to place the object in different variable values:
test3 = PROD : {name :“prod”, value:1} , STG : {name :“stg”, value:2}
And get the value ${test3}. value.
why can’t you use an object as a value in grafana?
