v9.4.7 -
get the last value, so there is always a value displayed, even if not: -
What happened?
Due to API Limitations I can only fetch data very rarely. Some components does only work with “Event Polling”. So there could be the same data for a long time. -
As said, it is possible that the last entry in db is like 3 days ago, but the value never changed (i just don´t save the same value again, due to very high db usage)
So currently, if I have the same value a long time, there is no data displayed anymore. Currently I fill in the gaps withpreviousorlinear. But as soon as the last point is out of time I get no data display.
My goal:
Always have last data fillable withpreviousorlineareven if out of time scale -
My query:
SELECT mean("value") FROM "..." WHERE $timeFilter GROUP BY time($__interval) fill(previous)
Welcome
What is your data source?
What do you mean?
I use InfluxDB with Node-RED.
If it’s not what you wanted, please let me know
I am relatively new to grafana/influx
Thank you
Hi @vito0912,
Maybe you can just set longer time range for that specific panel like on next link?:
https://community.grafana.com/t/each-panel-has-its-own-timeline/79929/4?u=ldrascic
All other panels on that dashboard would have time range from time picker (in upper right corner).
Best regards,
ldrascic
so it looks like you are using influxql query language on influxdb. I wonder if there is a way to check the value of mean and conditionally choose the following use of last?
select last(field_1),* from measurement group by *
Thanks for your idea. However, this would only delay the problem and break the statisics, since a 6h view should be the case with me
It seems to work kind of. I modified it a little bit to work with my needs. It now finds the data (the % at top right is shown correctly). And also shows “data outside time range”. But it doesn´t show a graph. Even when using fill(previous)
F is my normal
H is “yours”
what does the data tab show, behind the graph
Thank you for this.
It seems to work OK when the time range is set to get the all last values
Example: Last 12 hours
When I set the time range to Last 5 minutes or Last 1 hour Grafana will exclude all (or some) queries
Any solution to this?
Br,
kd
Best way I found so far: (in fluxDB)
Do a sort of pre-fetch by selecting a slightly larger period, using the fill(useprevious)
And then reducing te selection again to the original range.
import “date”
from(bucket: “Insights”)
|> range(start: date.sub(d: 24h, from: v.timeRangeStart), stop: v.timeRangeStop)
|> filter(fn: (r) => r[“_field”] == “measure_humidity”)
|> aggregateWindow(every: v.windowPeriod, fn: mean, createEmpty: true)
|> fill(usePrevious: true)
|> yield(name: “last”)
