Seems like CARTO has just deployed this watermark for any tile requests with no API key that uses it.
Anyone can request a free API key - I have just gotten mine now. But not sure where to inject this - I would assume on the JSON panel somewhere.
Can someone guide the community please?
Regards,
Carlo
I solved it by:
Edit the Pane
Basemap layer
[Layer type] → arcGIS MapServer
[Server instance] → Custom MapServer
[URL Template] = https://basemaps.cartocdn.com/rastertiles/dark_all/{z}/{x}/{y}.png?key={YOUR_API_KEY}
[Attribution] = carto dot com //limited to 2 links, sorry.
Refer to their github for styling: https://github.com/cartodb/basemap-styles
I went with the dark_all style
vaduga
August 30, 2026, 12:22pm
4
Still makes sense to file an issue at Grafana’s github. The whole story with Carto api key seems like an attempt to shake off users from heavy raster tiles to use vector tiles instead - these don’t require api key (on purpose, I think), and it doesn’t take much of a change to use the /vector URL in geomap source code.
Tbm estou com esse problema usava sem a marca agua, mas agora so consegui usar assim
no Json do mapa alterei o campo
“basemap”: {
"config": {},
"name": "Layer 0",
"type": "default"
POR
“basemap”: {
"config": {
"attribution": "© OpenStreetMap contributors © CARTO",
"server": {
"url": "https://basemaps.cartocdn.com/rastertiles/voyager/{z}/{x}/{y}.png?key=XXXXXXXXXXXXXXXXXXXXXXXXXXXX"
"name": "CARTO Voyager",
"type": "xyz"
Fixed by adding this to my /etc/grafana/grafana.ini
[geomap]
default_baselayer_config = {"type":"xyz","config":{"attribution":"© CARTO © OpenStreetMap contributors","url":"https://basemaps.cartocdn.com/rastertiles/voyager/{z}/{x}/{y}.png?key=<KEY>"}}
yosiasz
October 14, 2026, 11:16am
8
Upgrade to latest also fixes this issue
