Generic OAuth with Auth0
Hey there,
I am trying to set up OAuth with Auth0 following the docs and the discussion at Auth0 authentication support however I am getting the following error:
login.OAuthLogin(NewTransportWithCode) logger=context userId=0 orgId=0 uname= error=“oauth2: cannot fetch token: 400 Bad Request\nResponse: {“error”:“invalid_request”,“error_description”:“missing access_token parameter”}”
I am using the latest stable version of Grafana (5.0.0).
Any help would be appreciated.
Thanks
Dimitris
Hey,
Have you checked the documentation?
Marcus
Yeah as mentioned I followed the docs at Configure Grafana | Grafana documentation and the respective thread posted above.
My config looks like this:
[server]
root_url = ROOT_URL
[auth.generic_oauth]
enabled = true
allow_sign_up = true
team_ids =
allowed_organizations =
name = Auth0
client_id = AUTH0_CLIENT_ID
client_secret = AUTH0_CLIENT_SECRET
scopes = openid profile email
auth_url = AUTH0_DOMAIN/authorize
token_url = AUTH0_DOMAIN/oauth/access_token
api_url = AUTH0_DOMAIN/userinfo
The error occurs after I successfully authenticate with auth0 and then I get redirected back to our Grafana setup. The request is the following:
https://ourdomain/login/generic_oauth?code=CODE&state=STATE
Cookie: grafana_sess=GRAFANA_SESS
The response is a 500 with the and the logs are mentioned in my original message.
Thanks
Dimitris
Have you configured your callback url correctly?
Marcus
Hey
Given that the call returns back to grafana, after I authenticate with Auth0, I assume it is. It looks like this ROOT_URL/login/generic_oauth, where ROOT_URL the full URL as set in the server section of the settings (eg.: ROOT_URL=https://example.com/ and in Auth0 callback_url: https://example.com/login/generic_oauth).
Could the error missing access_token parameter be a pointer for something particular?
Cheers
Dimitris
Error are coming from oauth2 library where using. https://github.com/golang/oauth2/search?utf8=✓&q=cannot+fetch+token&type=
But seems to me that it is auth0 that returns a response with 400 Bad Request\nResponse: {“error”:“invalid_request”,“error_description”:“missing access_token parameter”}”
Marcus
