Generic OAuth: Organization assignment ignored, users always put into "Main Org."
    Grafana 11.1.0 on Linux
    I’d like to map users to the correct organization via the auth token. This is to achieve dashboard separation for privacy, security, etc.
    The OAuth token is as such:
  "org:" {
    "org-nameA"
  "role": {
    "Viewer"
Here is my configuration:
grafana.ini:
  server:
	domain: <redacted>
  log:
	filters:
	  oauth.generic_oath:debug
  auth:
	disable_login_form: false
  auth.generic_oauth:
	enabled: true
	auth_url: <redacted>
	token_url: <redacted>
	api_url: <redacted>
	client_id: <redacted>
	scopes: profile email openid
	email_attribute_name: email
	name_attribute_path: unique_name
	role_attribute_path: role
	org_attribute_path: org
	org_mapping: 'main-org:1:Admin, org-NameA:2:Viewer, orgNameB:3:Viewer'
	allow_assign_grafana_admin: true
  users:
	auto_assign_org: false
  • What happened?
    Newly authenticated user with that token is always placed in the Main Org as a viewer.
    Newly authenticated user with that token is placed in org-NameA as a viewer.
I know that role_attribute_path is working because I can change the value in the token and the user will be authenticated as that role. What am I missing? Any help will be greatly appreciated.
