grafana 6.4; debian os
- What are you trying to achieve?
I tried to search users via http api.
- How are you trying to achieve it?
- I generated an API key as Admin role
- I sent a http request:
GET /api/users?perpage=10&page=1
and use the api key in basic auth: username is api_key, password is the key itself.
- What happened?
response is { "message": "Permission denied" }
It should work and return the users.
