Filtering rows in a table by several values, filtering columns
I would like to know if there exists a table plugin that filter rows by several values (or substrings values). Also, I would like to apply the same concept by columns… “or” values… if I write a value for column 1 and another one for column 2 I would like to obatin rows with column1=value1 or column2=value2.
Thanks!
Paula
Hi, did you find a solution?
I stumbled upon the same problem.
Thanks.
Hi @shavitdevops,
Welcome to the :grafana: community support forums !!
Did you already check the documentation regarding it i.e. Transformations, which is very powerful and useful to filter out the data you need:
I hope this helps.
