Grafana v8.5.21, Opensearch data source -
I want to filter my data series based on the difference between two timestamps. I have two fields -data.tstampanddata.last_accessedand I want to filter my data where I only see data that hasdata.last_accessedmore than three months older thandata.tstamp. -
I have added filterdata.last_accessed:<data.tstamp-3M -
What happened?
Filter didn’t work. -
I have checked online, but none of the suggestions worked.
