Filter by clicking in value
Hello, i don’t know how to explain this but i have my Grafana dashboard and I want to filter all my panels my clicking in one value (for example, by clicking in on the legends in Pie chart, i want to filter that value for all my panels that match that value, sort of what Kibana does and the Table panel). For giving an exact example, i have a piechart with a list of IPs and I want to click that IP and filter that value in my geomap (or in my other panel that i other information/fields)
have you tried using data-link variables?
Hello, I don’t to redirect or open a new tab. Only click the value and the filter all other panels based on that value. Can I do that with Data links?
hey,
did you find any answer to your question?
Hi, not sure if this is what you want but you can enable something similar in the overrides of the panel. Create a new override for the fields you want (in your case probably Fields with Name: IP) then in the override property add Standard Options > Ad-Hoc filterable
