I am trying to do simple addition using Transform : Add field from calculation. But when one of the field is having no data the calculation don’t work. To fix that I tried to fill it with 0, but it is not working. My query looks like this:
SELECT sum(diff) from ( select non_negative_difference(“value”) as diff FROM “counter” WHERE (“tag_name” = ‘tag1’) AND $timeFilter fill(0) )
Same case is with many other queries also, any way to replace no data with 0?
can you please follow these steps to share your raw unformatted data? That way, the community can try and mock up your problem
Raw Data looks something like this:
| Time |
B |
| 02-12-2021 10:59:49 |
1485 |
| 16-12-2021 19:15:15 |
1485 |
| 17-12-2021 18:36:09 |
1485 |
| 20-12-2021 21:52:13 |
1485 |
| 22-12-2021 13:51:15 |
1485 |
| 23-12-2021 20:31:57 |
1485 |
| 23-12-2021 22:20:14 |
1485 |
| Time |
A |
| 24-11-2021 16:37:24 |
111829 |
| 24-11-2021 16:37:25 |
111829 |
| 24-11-2021 16:37:27 |
111829 |
| 24-11-2021 16:37:29 |
111829 |
| 24-11-2021 16:37:30 |
111829 |
| 24-11-2021 16:37:32 |
111829 |
| 24-11-2021 16:37:33 |
111829 |
| 24-11-2021 16:37:35 |
111829 |
| 24-11-2021 16:37:37 |
111829 |
| 24-11-2021 16:37:38 |
111829 |
| 24-11-2021 16:37:40 |
111829 |
| 24-11-2021 16:37:41 |
111829 |
| 24-11-2021 16:37:43 |
111829 |
| 24-11-2021 16:37:45 |
111829 |
| 24-11-2021 16:37:46 |
111829 |
| 24-11-2021 16:37:48 |
111829 |
| 24-11-2021 16:37:49 |
111829 |
| 24-11-2021 16:37:51 |
111829 |
| 24-11-2021 16:37:53 |
111829 |
| 24-11-2021 16:37:54 |
111829 |
| 24-11-2021 16:37:57 |
111829 |
| 24-11-2021 16:37:59 |
111829 |
| 24-11-2021 16:38:01 |
111829 |
| 24-11-2021 16:38:02 |
111829 |
| 24-11-2021 16:38:04 |
111829 |
| 24-11-2021 16:38:05 |
111829 |
| 24-11-2021 16:38:07 |
111829 |
| 24-11-2021 16:38:10 |
111829 |
| 24-11-2021 16:38:13 |
111830 |
| 24-11-2021 16:38:15 |
111830 |
| 24-11-2021 16:38:17 |
111830 |
| 24-11-2021 16:38:18 |
111830 |
| 24-11-2021 16:38:20 |
111830 |
| 24-11-2021 16:38:21 |
111830 |
| 24-11-2021 16:38:23 |
111830 |
| 24-11-2021 16:38:25 |
111830 |
| 24-11-2021 16:38:26 |
111830 |
| 24-11-2021 16:38:28 |
111830 |
| 24-11-2021 16:38:29 |
111830 |
| 24-11-2021 16:38:31 |
111830 |
| 24-11-2021 16:38:33 |
111830 |
| 24-11-2021 16:38:34 |
111830 |
| 24-11-2021 16:38:36 |
111830 |
| 24-11-2021 16:38:37 |
111830 |
| 24-11-2021 16:38:39 |
111830 |
| 24-11-2021 16:38:41 |
111830 |
| 24-11-2021 16:38:42 |
111830 |
| 24-11-2021 16:38:44 |
111830 |
| 24-11-2021 16:38:45 |
111830 |
| 24-11-2021 16:38:47 |
111830 |
| 24-11-2021 16:38:49 |
111830 |
| 24-11-2021 16:38:50 |
111830 |
| 24-11-2021 16:38:52 |
111830 |
| 24-11-2021 16:38:53 |
111830 |
| 24-11-2021 16:38:55 |
111830 |
| 24-11-2021 16:38:57 |
111830 |
Hi @anon70503803 , any solution to this ?
sorry @satbirsingh just getting back from the holiday break. Will try and mock this up this week. more soon
@satbirsingh can you check out this dashboard? Please let me know if you can’t access it.
https://play.grafana.org/d/s8ep4PAnz/mja-add-field-transformation?orgId=1
I mocked your data and think I have what you want. Using the reduce method inside the add field from calculation seems to handle empty values.
@anon70503803, thanks for the solution. This works good when adding two fields, but not when we are subtracting two. I have subtractions and divisions as well in my calculations. Difference using reduce row leads to zero value when null values are present.
ok I think I got this working. Check out the updated dashboard. If you select the special value mapping option, then you can value map things like null, NaN, and undefined. Using that and then explicitly setting the fields as numbers not strings, and voila:
I added a constant value to the database that stores “1” and request it along with the rest of the data through an additional SELECT, this prevents the absence of data, sorry for my english
Hi - just tried to adopt your dashboard to my data - your solution is working as long as you don’t exclude data with “Where” command eg:
SELECT “Bezug” FROM “AC” WHERE (“Bezug” > 0) AND $timeFilter
the field “Bezug” can contain negative and positive data - for my calculation I only need the positive one
