I don’t know about you folks, but after months of creating and tweaking so many dashboards, user access, data sources, various plugins, etc., I can’t say I would be able to easily recreate all that if my server died and my data was lost. But I DO know it would take a WHILE.
So many of you might say, “well, actually, all you have to do is back up SQLLite,” or whatever - many of us have no idea how to do that, and it would be a bit different depending on what database you’re using to store your settings, or which OS you’re on (maybe).
So why not suggest either a plugin or core feature that replicates everything down to the last detail in a single file, right from the UI, which you could use to restore to a new instance of Grafana if your server died?
Related functions could include:
- Scheduled backups
- Email of that backup as an attachment
