Grafana docker instance (v 9.3) is installed on Azure cloud and is being configured to send alerts as email to a particular user in our domain.
For this reason, we created an email id (MS exchange server) in our domain and used the following SMTP configuration as given below (assume the mail id is username@domainname.com)
*[smtp]*
*enabled = true*
*host = smtp.office365.com:587*
*skip_verify=true*
*from_address = username@domainname.com*
*from_name = Grafana*
However, while trying to send a test email from grafana, we get the following error which says that SmtpClientAuthentication is disabled by Tenant. On discussing with the admin team, it seems this cannot be enabled and hence we are unable to use the above method for sending emails from Grafana.
- Are there any other ways of sending alerts as mails from grafana?
- If no, what could be the other alternative other than sending mails to inform a particular user about the alerts? Note that we have already done teams integration.
Thanks & Regards
Nisha
