v10.1.5
- What are you trying to achieve?
Show a panel drawing information from 2 different queries.
- How are you trying to achieve it?
I’ve added a new “Time series” panel and 2 queries inside. One gets the number of requests and the other shows the time it takes to answer:
- What happened?
When I have lots of information in influx, I get “Failed to fetch” when both queries are enabled. If I disable any of the two, the remaining one works as expected.
I expected to see both graphs as in my previous screenshot. If it fails I’d expect a better error at least.
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
“Failed to fetch”:
