Failed by threshold
Hello!
I’m starting to use K6 and Grafana. When I run it locally, no failures are shown, all tests pass.
When running k6 cloud run …spec… the tests fail with the message Failed by threshold. Looking through the documentation I couldn’t find anything that solved this problem.
Message Grafana: HTTP Failure Rate
Hi @brunorodrigues8,
welcome to the community forum :tada:
Please, post an anonymized and/or simplified version of your script so we can help you to troubleshoot it.
Otherwise, if you are a Grafana Cloud customer then I suggest opening a support ticket and it would be easier to support you directly.
I hope it helps.
