We need to export grafana dashboard in pdf or excel format. We checked in wiki page and it was mentioned it is available in Grafana Enterprise and Grafana Cloud.
Created Grafana cloud account and checked. But not able to proceed further.
Can you please help with the information to proceed further. We are not able to find options in Grafana cloud portal page.
We are using Grafana 10.3.1 in local to build the dashboard and export to pdf or excel format.
Thanks
K. Kiran Kumar
You can export a Grafana Cloud dashboard as a PDF by selecting the Share button located at the top of the dashboard near the right side of the screen:
From there, select the PDF option:
You can also schedule emailed reports of a dashboard PDF using the Reporting feature:
Note that you can also export the dashboard JSON directly:
The PDF export option and Reporting feature are only available with an active Grafana Enterprise license or any Grafana Cloud plan. Exporting a dashboard JSON is available for Grafana open source software (OSS), Grafana Enterprise, and all Grafana Cloud plans.
For other sharing options, see: Share dashboards and panels | Grafana documentation
You can avoid the needs of an active Grafana Enterprise license by using this free project to easily generate a PDF of your entire dashboard or individual panel : GitHub - arthur-mdn/ExportGrafanaDashboardToPDF: Free PDF Export Tool in Grafana Community version - Using Puppeteer
