v11.6.0 (d2fdff9ee4) -
I’m trying to scrape metrics with trace IDs and store them in Mimir to visualize exemplars in a Grafana dashboard panel. -
I have a set of docker containers (Grafana, Prometheus, Mimir, Tempo, OpenTelemetry Collector and Loki) and a little hello world Golang application that is emitting metrics with the Span & Trace information embedded into the a metric (counter). I can see the metrics:
curl -s "http://localhost:9464/metrics" | head -n10
# HELP sre_my_counter_total
# TYPE sre_my_counter_total counter
sre_my_counter_total{job="metal-app",operacao="oi"} 80
sre_my_counter_total{job="metal-app",operacao="oi",span_id="01c2cf445ba75703",trace_id="b945f37a1d57ad1f14a39baaf95f174e"} 1
sre_my_counter_total{job="metal-app",operacao="oi",span_id="0244deb2e70ae91c",trace_id="d5c1c215b10aeae6e842e06ac3013fba"} 1
I initialized Prometheus with the --enable-feature=exemplar-storage
flag.
I also added the following remote_write
configuration to Prometheus to send the metrics over to Mimir:
remote_write:
- url: "http://mimir:9009/api/v1/push"
send_exemplars: true
I also added the max_global_exemplars_per_user
parameter to my mimir-config.yml
limits:
max_global_exemplars_per_user: 100000
Then, in my local Grafana, I just can’t make the exemplars show up. When I mouseover the datapoints I can see the span_id
and trace_id
labels in the metric but the fancy exemplars dialog just doesn’t show up. I have configured the Tempo datasource, confirmed the traces are flowing, and even my Mimir data source has the Exemplar’s configuration set against “internal link = Tempo” with the “label name = trace_id”. How do I enable the exemplars visualization on my dashboard panel?
What happened?
I just can’t make the exemplars show up. I tried to toggle the “Exemplars” option under the panel’s query options, but that did not help. -
I just want to see the exemplars floating dialog / modal with the metric information containing a link to the trace ID. -
I have the experiment’s artifacts available here:
Comparing main...experiment-with-exemplars · themarcelor/metal-app · GitHub -
I didn’t get any errors in the Grafana UI. -
I followed some of these steps here:
https://grafana.com/docs/mimir/latest/manage/use-exemplars/before-you-begin/
and the rest of the configuration I put together through additional research after trying several different things.
