Grafana is great and now it would be even better to have UI more event based than fixed 5s or less How to change refresh-rate from 5s to 1s - #4 by romanpercev for sure there is possibility to have wrong (DDOS) , anyhow in my use case I would like to refresh the UI by using any means possible e.g. API, some event mechanics. Is there to trigger the UI “draw” based on some event or can I call some API endpoint to do that ? thanks
Hi @ristosaa,
The new streaming panel, introduced in v7.5.4, (see bottom panel), can stream data at 30fps
