What happened:
Our team has its own graph deployed on. In its functionality, I ran into a problem: the parameters do not work in the dashboard variable: (screenshot in the attachment).
In my opinion, the Multi-value parameter is not parsed, since if you select one element, the request works, and the Include All option parameter does not work completely, since when you select it, the panel freezes and is not updated.
How to reproduce it (as minimally and precisely as possible):
Versions of grafana and druid I set below. I use druid sql syntax to print data (screenshot in the attachment).
Environment:
- Grafana version: grafana-enterprise:9.0.0-beta3, grafana:latest, grafana:main
- Data source type & version: druid 0.22.1
- OS Grafana is installed on: linux
- User OS & Browser: Safari
- Grafana plugins: grafadruid-druid-datasource
sql query used:
SELECT
__time as "time",
name as "service",
count(sla) as " "
FROM SYTESTER_DRUID
WHERE name in ('${service}')
AND __time >= MILLIS_TO_TIMESTAMP(${__from}) AND __time <= MILLIS_TO_TIMESTAMP(${__to})
GROUP BY __time, name
I call variable “service” in look like ‘$service’ and ‘${service}’. I received the same error in both cases.
Maybe I make something wrong?
It does not allow to me upload images in this topic(((
