Hi I try with this important command but I got an error…
I don’t understand why?
logcli series '{job="mysql"}' --analyze-labels
end the err
logcli: error: expected command but got "series", try --help
Naturally others run like:
logcli query '{job="mysql"}'
logcli labels job
Thanks ALEN
@alencappelletti hi, thanks for the question.
Try swapping the arguments:
logcli series --analyze-labels '{job="mysql"}'
Hi danny…
no always the same…
[acap@localhost ~]$ logcli labels job
http://localhost:3100/loki/api/v1/label/job/values
docker
mysql
postgres
sqlserver
sqlservernamed
[acap@localhost ~]$ logcli series --analyze-labels ‘{job=“mysql”}’
logcli: error: expected command but got “series”, try --help
Do you have some ideas about?
Which version of logcli are you using, and on which OS?
This are the details:
logcli, version 1.4.1 (branch: HEAD, revision: 2445ccd2)
build user: root@bb5e00b6b7f4
build date: 2020-04-06T20:29:26Z
go version: go1.13.4
this is OS
Static hostname: localhost.localdomain
Icon name: computer-vm
Chassis: vm
Machine ID: 3017c69a44b34070bc15425610ac4de8
Boot ID: 778131206d4b4f72b4445874e1987bed
Virtualization: vmware
Operating System: Red Hat Enterprise Linux 8.5 (Ootpa)
CPE OS Name: cpe:/o:redhat:enterprise_linux:8::baseos
Kernel: Linux 4.18.0-348.12.2.el8_5.x86_64
Architecture: x86-64
Please let me know how can you see the specifications of the labels?
Alen
Please update to the latest logcli: Releases · grafana/loki · GitHub
You’re running an almost 2 year old version.
Thank you very much Danny…
now it’s ok…
I mistakenly downloaded a wrong version from GitHub and didn’t notice.
Thanks again!
p.s .: is there a version in the docker of logcli? However I installed it on the host.
Hi Danny…
Id downloaded the client directly previously, due to the underlying error
Error response from daemon: manifest for grafana/logcli:latest not found: manifest unknown: manifest unknown
For this reason I was unable to include it in the docker. Is there any action I can take to elude the message?
Thanks Alen
