Error processing requests-rpc error: code = Canceled desc = context canceled
On Monolithic setup, Loki 2.9.14 + S3 + memberlist
gets the below error while searching in Grafana. Please find attached the configuration also.
level=error ts=2025-06-11T12:47:26.874670158Z caller=frontend_processor.go:69 msg="error processing requests" address=127.0.0.1:9095 err="rpc error: code = Canceled desc = context canceled"
level=error ts=2025-06-11T12:47:26.87498672Z caller=frontend_processor.go:145 msg="error processing requests" err=EOF
Loki configuration:
# Loki 2.9.14 + S3 + memberlist - prod
# target:
auth_enabled: false
ballast_bytes: 10000  # default = 0
server:
  # http_listen_address: 127.0.0.1  # default = "" - comment in production
  http_listen_port: 3101  # 3101 - make in production
  grpc_listen_address: 127.0.0.1  # default = ""
  grpc_listen_port: 9095
  http_server_read_timeout: 10m  # default = 30s
  http_server_write_timeout: 10m  # default = 30s
  http_server_idle_timeout: 5m  # default = 2m
  grpc_server_max_recv_msg_size: 41943040  # 40MB to handle long log lines, default = 4194304
  grpc_server_max_send_msg_size: 41943040  # 40MB to handle long log lines, default = 4194304
  grpc_server_max_concurrent_streams: 0 # default = 100 (0 = unlimited)
  log_level: warn
distributor:
  ring:
    kvstore:
      store: memberlist
    heartbeat_period: 0 # default = 5s
    heartbeat_timeout: 0 # default = 1m
querier:
  tail_max_duration: 1h  # default = 1h
  query_ingesters_within: 0 # default = 3h
  engine:
    timeout: 5m # default = 5m
    max_look_back_period: 168h  # 7 days, default = 30s
  max_concurrent: 4  # default = 4, 2-core CPU → 4, 4-core CPU → 8
query_scheduler:
  max_outstanding_requests_per_tenant: 64000 # default = 32000
  grpc_client_config:
    max_recv_msg_size: 209715200 # default = 104857600 (bytes)
    max_send_msg_size: 209715200 # default = 104857600 (bytes)
    grpc_compression: 'snappy'  # default = ""
    backoff_on_ratelimits: true # default = false
    connect_timeout: 0s # default = 5s
  use_scheduler_ring: false  # default = false
frontend:
  log_queries_longer_than: 60s  # default = 0s
  max_outstanding_per_tenant: 8192  # default = 2048
  grpc_client_config:
  compress_responses: true
query_range:
  align_queries_with_step: true # default = false
  results_cache:
    cache:
      embedded_cache:
        enabled: true # default = false
  cache_results: true # default = false
  max_retries: 15  # default = 5
  index_stats_results_cache:
    cache:
      embedded_cache:
ruler:
  storage:
    type: local
    local:
      directory: /data/loki/rules
  rule_path: /data/loki/rules/fake/
  alertmanager_url: http://127.0.0.1:9093
  enable_api: true
ingester_client:
  pool_config:
    client_cleanup_period: 20s  # default = 15s
    health_check_ingesters: false # default = true
    remote_timeout: 5s  # default = 1s
  remote_timeout: 10s # default = 5s
  grpc_client_config:
ingester:
  concurrent_flushes: 64  # default = 32
  flush_check_period: 30s # default = 30s
  flush_op_timeout: 10m # default = 10m
  chunk_retain_period: 5s  # To ease recovery, default = 0s
  chunk_idle_period: 30m  # Close chunks after no more writes, default = 30m
  chunk_block_size: 262144  # 256KB, default = 262144
  chunk_target_size: 1572864  # ~1.5MB target chunk size, default = 1572864
  chunk_encoding: "snappy"  # default = "gzip"
  max_chunk_age: 1h # default = 2h
  autoforget_unhealthy: false # default = false
  query_store_max_look_back_period: 0s  # default = 0s
  wal:
    enabled: true # default = true
    dir: /data/loki/wal
index_gateway:
  mode: "simple"  # default = "simple"
storage_config:
  tsdb_shipper:
    active_index_directory: /data/loki/tsdb-index
    shared_store: s3
    shared_store_key_prefix: "index/" # default = "index/"
    cache_location: /data/loki/tsdb-cache
    cache_ttl: 24h  # Can be increased for faster performance over longer query periods, uses more disk space
    resync_interval: 10m  # default = 5m
    query_ready_num_days: 1 # default = 0
    index_gateway_client:
      grpc_client_config:
      server_address: 127.0.0.1 # default = ""
  filesystem:
    directory: /data/loki/chunks
  aws:
    # s3: s3://<bucketName>
    s3forcepathstyle: true  # default = false
    bucketnames: <bucketName> # default = ""
    endpoint: s3.me-central-1.amazonaws.com # default = ""
    region: me-central-1  # default = ""
    # access_key_id: ${AWS_ACCESS_KEY_ID} # default = ""
    # secret_access_key: ${AWS_SECRET_ACCESS_KEY} # default = ""
    # session_token: ${AWS_SESSION_TOKEN} # default = ""
    insecure: false # default = false
    sse_encryption: false # default = false
  index_queries_cache_config:
    embedded_cache:
  max_parallel_get_chunk: 150 # default = 150
  max_chunk_batch_size: 50 # default = 50
chunk_store_config:
  chunk_cache_config:
    embedded_cache:
schema_config:
  configs:
    store: tsdb
    object_store: s3
    schema: v12
    index:
      prefix: index_
      period: 24h
    chunks:
      prefix: chunks_
      period: 24h
compactor:
  working_directory: /data/loki/compactor
  compaction_interval: 5m # default = 10m
  retention_enabled: true # default = false
  retention_delete_delay: 1h  # default = 2h
  retention_delete_worker_count: 150  # default = 150
  delete_request_store: s3  # default = ""
  delete_batch_size: 100  # default = 70
  max_compaction_parallelism: 2 # default = 1
  tables_to_compact: 0  # default = 0
limits_config:
  ingestion_rate_mb: 500  # 500MB/s, default = 4
  ingestion_burst_size_mb: 1000  # Burst capability for spikes, default = 6
  max_label_name_length: 1024 # default = 1024
  max_label_value_length: 5120  # default = 2048
  reject_old_samples: true
  reject_old_samples_max_age: 2w  # default = 1w (window) = max_chunk_age/2
  max_line_size: 0B # 10MB to handle long log lines, default = 0B
  max_global_streams_per_user: 100000 # default = 5000
  per_stream_rate_limit: 20MB # default = 3MB
  per_stream_rate_limit_burst: 40MB # default = 15MB
  max_query_parallelism: 64 # default = 32
  tsdb_max_query_parallelism: 32  # default = 128
  max_entries_limit_per_query: 5000  # default = 5000
  split_queries_by_interval: 1h # default = 1h
  volume_enabled: true
  retention_period: 168h  # 7 days retention
frontend_worker:
  frontend_address: 127.0.0.1:9095 # default = ""
  # scheduler_address: 127.0.0.1:9095 # default = ""
  grpc_client_config:
table_manager:
  retention_deletes_enabled: true # default = false
memberlist:
 gossip_interval: 200ms  # default = 200ms
 gossip_nodes: 1  # default = 3
 gossip_to_dead_nodes_time: 30s # default = 30s
 advertise_addr: 127.0.0.1 # default = ""
 advertise_port: 7946 # default = 7946
 join_members: # default = []
   - 127.0.0.1:7946
 left_ingesters_timeout: 5m # default = 5m
 bind_addr: ['127.0.0.1']  # default = []
 bind_port: 7946 # default = 7946
# runtime_config:
# tracing:
analytics:
  reporting_enabled: false
common:
  path_prefix: /data/loki
  storage:
    s3:
  persist_tokens: true
  replication_factor: 1
  ring:
    kvstore:
      store: memberlist
      prefix: "collectors/" # default = "collectors/"
    heartbeat_period: 0 # default = 15s
    instance_port: 9095 # default = 0
    instance_addr: 127.0.0.1
  compactor_address: 127.0.0.1:3100  # default = ""
  compactor_grpc_address: 127.0.0.1:9095  # default = ""
shutdown_delay: 3s  # # default = 0s
  1. What does your loki container resource usage look like?
  2. Do you see any other error message before the RCP error?
  1. What does your Loki container resource usage look like?
    Ans: - since the last 1 week or the period when the error occurred (Loki on EC2)
    1. CPU % utilization - 4-5 % range
    2. mem_used_percent - 12-13 % range
    3. disk_used_percent - 14-15 % range
    4. mem_free - 400-500 M range
    Ans: Yes, below was error just before rpc error
level=error ts=2025-06-11T12:45:21.591758767Z caller=http.go:320 org_id=fake traceID=1858c939ae8a4460 msg="Unexpected error from client" err="read tcp 10.41.3.89:3101->172.20.12.5:63163: read: connection reset by peer"
level=error ts=2025-06-11T12:45:43.61537618Z caller=http.go:320 org_id=fake traceID=68d1ad137b4a9b6f msg="Unexpected error from client" err="read tcp 10.41.3.89:3101->172.20.12.5:63166: read: connection reset by peer"
level=error ts=2025-06-11T12:46:21.06735062Z caller=http.go:320 org_id=fake traceID=4ed0bec6715445f6 msg="Unexpected error from client" err="read tcp 10.41.3.89:3101->172.20.12.5:63183: read: connection reset by peer"
level=error ts=2025-06-11T12:46:37.579577091Z caller=frontend_processor.go:69 msg="error processing requests" address=127.0.0.1:9095 err="rpc error: code = Canceled desc = context canceled"
level=error ts=2025-06-11T12:46:37.579632886Z caller=retry.go:73 org_id=fake traceID=2decf77901c9995e msg="error processing request" try=0 query="{name=\"loki-canary\"} |= \"\"" err="context canceled"
level=error ts=2025-06-11T12:47:25.259761856Z caller=frontend_processor.go:69 msg="error processing requests" address=127.0.0.1:9095 err="rpc error: code = Canceled desc = context canceled"
level=error ts=2025-06-11T12:47:25.259833429Z caller=retry.go:73 org_id=fake traceID=70584f41e20bf3e3 msg="error processing request" try=0 query="{stream=\"stdout\"} |= \"\"" err="context canceled"
  1. Does it work some of the time or does it not work at all?
  2. I see you are using 127.0.0.1 for most of your endpoints, is there a reason for this?
  1. Does it work some of the time, or does it not work at all?
    Ans: Yes, it does work sometimes and sometimes not.
    Ans: Yes, I am having a monolithic setup on a single VM/node locally, that is why I am using 127.0.0.1.
Anyway, do you find anything wrong/mistake in the configuration for this Loki v2.9.14?
I don’t see anything obviously wrong. If it’s context error I’d check resource usage and see if there is any error message from Loki on some sort of limits being hit.
I would also recommend you to change to 0.0.0.0 just as a test and see if that helps.
Even changing to 0.0.0.0 from 127.0.0.1 gives a similar error,
level=error ts=2025-06-27T11:24:10.46182Z caller=frontend_processor.go:69 msg="error processing requests" address=0.0.0.0:9095 err="rpc error: code = Canceled desc = context canceled"
level=error ts=2025-06-27T11:24:10.461851Z caller=frontend_processor.go:145 msg="error processing requests" err=EOF
level=error ts=2025-06-27T11:24:10.461713Z caller=retry.go:73 org_id=fake traceID=105b345ea687affc msg="error processing request" try=0 query="{name=\"loki-canary\"} |= \"\"" err="context canceled"
But how much should I care about this error?, Can I neglect this?
