11.6.0 SLES 15 SP6 -
Get a 24/7 running playlist -
Proxiing grafana through nginx, starting playlist via Grafana Kiosk Software from github -
What happened?
Playlist fails after some time with error “Page Not Found” and i can see that it switches address from /grafana to /grafana/grafana
Playlist to function normally without crashing -
nginx config:
location ~/grafana(.*)$ {
rewrite ^/grafana/(.*) /$1 break;
proxy_set_header Host $host;
proxy_pass http://127.0.0.1:3000;
proxy_connect_timeout 7d;
proxy_send_timeout 7d;
proxy_read_timeout 7d;
# Proxy Grafana Live WebSocket connections.
location /grafana/api/live/ {
proxy_http_version 1.1; proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection $connection_upgrade;
Grafana.ini
[server]
# Protocol (http, https, socket)
protocol = http
# The ip address to bind to, empty will bind to all interfaces
#http_addr = 127.0.0.1
# The http port to use
;http_port = 3000
# The public facing domain name used to access grafana from a browser
domain = server.abc.de
# Redirect to correct domain if host header does not match domain
# Prevents DNS rebinding attacks
;enforce_domain = false
# The full public facing url you use in browser, used for redirects and emails
# If you use reverse proxy and sub path specify full url (with sub path)
root_url = https://server.abc.de/grafana/
serve_from_sub_path = false
Grafana UI: Page not found -
Run Grafana behind a reverse proxy | Grafana Labs
