I’m newbie on implementing the grafana. I was build my grafana server on my guest VM that used the ubuntu-server 22.04.5 version. I want to visualize from JSON data. Some of JSON has the many different size, but many of them is more than 1GB size. My plan for visualize that is using Infinity plugins, so I make a connection and make a dashboard for the first time, then I upload that JSON, but I get the error “out of memory” from the browser that I used. What’s the problem, whereis it, is it on the grafana server, browser, or the other? Can somebody give the solution? Thank you very much
