I’ve installed Grafana on an RASPI with a local mySQL-DB.
Everything runs fine.
Now i want to start with a new MySQL Connection.
This results in an error: “db query error: query failed - please inspect Grafana server log for details”
The user can open the db and select queries.
The file is: /var/log/grafana/grafana.log
But then i get the next error when i want to open this logfile: failed to open the file.
Logged in as admin.
But why can’t i open the file? Any ideas?
Does this mean Grafana is using MySQL already?
Does this mean you are trying to add an extra connection, or is this the first connection?
Please tell us exactly what “this” is - in other words, what have you entered
into Grafana in order to get the error message?
details”
Which user? How are you verifying this?
open the file. Logged in as admin.
Please show us what command you are trying to use to open the file, and the
error message which results.
Additional helpful information:
the output of the command “whoami”
the output of the command “ls -l /var/log/grafana”
