I have a data source with influx 2.0 that generates a dashboard with a simple percentage account in table mode, but I can’t create a time series rule where the result reaches a certain value, there are several devices more than 900
Does your query give you good results (i.e. a time series graph) when you run the query in Influx Data Explorer?
Yes, return all datas in model single
Alerting works when the underlying query returns numeric data. The error message you received means numeric data is not being returned. I have also received this error, and went back to Influx Data Explorer and played with it there before moving it to Grafana alerting. Can you show a screenshot of the query and numeric output working in Influx Data Explorer?
