Hello , I am also facing the same issue while running the script
ERRO[0000] could not initialize ‘Documents/k6_perf_POC/frontendScripts/fillform.js’: could not load JS test ‘file:///Users/tripate/Documents/k6_perf_POC/frontendScripts/fillform.js’: file:///Users/tripate/Documents/k6_perf_POC/frontendScripts/fillform.js: Line 19:25 Unexpected token function (and 6 more errors)
Your script contains references to Async / Await JS API, probably because you copied it directly from xk6-browser Github repo, but this feature is currently in development and about to be released in v0.8.0.
So if you are using v0.7.0 of xk6-browser, which is the latest released, you should use this version of the script. You an also build xk6-browse from source to get the current version in development following this instructions. Or wait for the v0.8.0 release which should come out soon this week.
