Endpoint deprecation
Hello Loki !
I found that one of your endpoint (the most important one indeed ) is being deprecated.
When it will be totally removed ?
Do you have a roadmap about this ?
Regards
J\x00
Hi @jgodinc2c
The documentation states that you should use /loki/api/v1/push instead; what is your specific concern about this deprecated endpoint?
To answer your question: we have no immediate plans to remove it entirely - perhaps when we release Loki v3.0.
I am updating some software that uses the old endpoint to the new one, and i dont really want to break stuffs on the user side.
I guess the best option here is to use the old endpoint as default and settup the new one as configuration option.
