v8.3.1 -
We are trying to template a variable to pull ec2 instance for the emr cluster to display cpu, memory metrics. -
dimension_values($region,AWS/EMR,ClusterId,InstanceId,{“ClusterId”: “{{ $jobflowid }}”}) -
What happened?
The above query returns NONE. -
It should return the associated ec2 instance for a EMR cluster -
Yes -
No -
