I have created grafana/loki using istio and deployed in openshift.
When i was trying to test with promtail i was facing below error
level=warn ts=2021-08-13T10:42:42.205933Z caller=client.go:344 component=client host=api.*.appdomain.cloud msg=“error sending batch, will retry” status=500 error="server returned HTTP status 500 Internal Server Error (500): empty ring"
Please find the attached configmap.yml
apiVersion: v1
data:
config.yaml: |-
"auth_enabled": true
"chunk_store_config":
"max_look_back_period": "0s"
"compactor":
"compaction_interval": "2h"
"shared_store": "s3"
"working_directory": "/data/loki/compactor"
"distributor":
"ring":
"kvstore":
"store": "memberlist"
"frontend":
"compress_responses": true
"max_outstanding_per_tenant": 200
"frontend_worker":
"frontend_address": "observatorium-xyz-loki-query-frontend-grpc.observatorium.svc.cluster.local:9095"
"grpc_client_config":
"max_send_msg_size": 104857600
"parallelism": 32
"ingester":
"chunk_block_size": 262144
"chunk_encoding": "snappy"
"chunk_idle_period": "2h"
"chunk_retain_period": "1m"
"chunk_target_size": 1572864
"lifecycler":
"heartbeat_period": "5s"
"interface_names":
- "eth0"
"join_after": "60s"
"num_tokens": 512
"ring":
"heartbeat_timeout": "1m"
"kvstore":
"replication_factor": 3
"max_transfer_retries": 0
"ingester_client":
"max_recv_msg_size": 67108864
"remote_timeout": "1s"
"limits_config":
"enforce_metric_name": false
"ingestion_burst_size_mb": 20
"ingestion_rate_mb": 10
"ingestion_rate_strategy": "global"
"max_cache_freshness_per_query": "10m"
"max_global_streams_per_user": 10000
"max_query_length": "12000h"
"max_query_parallelism": 32
"max_streams_per_user": 0
"reject_old_samples": true
"reject_old_samples_max_age": "24h"
"memberlist":
"abort_if_cluster_join_fails": false
"bind_port": 7946
"join_members":
- "observatorium-xyz-loki-gossip-ring.observatorium.svc.cluster.local:7946"
"max_join_backoff": "1m"
"max_join_retries": 10
"min_join_backoff": "1s"
"querier":
"engine":
"max_look_back_period": "5m"
"timeout": "3m"
"extra_query_delay": "0s"
"query_ingesters_within": "2h"
"query_timeout": "1h"
"tail_max_duration": "1h"
"query_range":
"align_queries_with_step": true
"cache_results": true
"max_retries": 5
"split_queries_by_interval": "30m"
"schema_config":
"configs":
- "from": "2020-10-01"
"index":
"period": "24h"
"prefix": "loki_index_"
"object_store": "s3"
"schema": "v11"
"store": "boltdb-shipper"
"server":
"graceful_shutdown_timeout": "5s"
"grpc_server_max_concurrent_streams": 1000
"grpc_server_max_recv_msg_size": 104857600
"grpc_server_max_send_msg_size": 104857600
"http_listen_port": 3100
"http_server_idle_timeout": "120s"
"http_server_write_timeout": "1m"
"storage_config":
"boltdb_shipper":
"active_index_directory": "/data/loki/index"
"cache_location": "/data/loki/index_cache"
"cache_ttl": "24h"
"resync_interval": "5m"
overrides.yaml: '{}'
kind: ConfigMap
metadata:
annotations:
kubectl.kubernetes.io/last-applied-configuration: |
{"apiVersion":"v1","data":{"config.yaml":"\"auth_enabled\": true\n\"chunk_store_config\":\n \"max_look_back_period\": \"0s\"\n\"compactor\":\n \"compaction_interval\": \"2h\"\n \"shared_store\": \"s3\"\n \"working_directory\": \"/data/loki/compactor\"\n\"distributor\":\n \"ring\":\n \"kvstore\":\n \"store\": \"memberlist\"\n\"frontend\":\n \"compress_responses\": true\n \"max_outstanding_per_tenant\": 200\n\"frontend_worker\":\n \"frontend_address\": \"observatorium-xyz-loki-query-frontend-grpc.observatorium.svc.cluster.local:9095\"\n \"grpc_client_config\":\n \"max_send_msg_size\": 104857600\n \"parallelism\": 32\n\"ingester\":\n \"chunk_block_size\": 262144\n \"chunk_encoding\": \"snappy\"\n \"chunk_idle_period\": \"2h\"\n \"chunk_retain_period\": \"1m\"\n \"chunk_target_size\": 1572864\n \"lifecycler\":\n \"heartbeat_period\": \"5s\"\n \"interface_names\":\n - \"eth0\"\n \"join_after\": \"60s\"\n \"num_tokens\": 512\n \"ring\":\n \"heartbeat_timeout\": \"1m\"\n \"kvstore\":\n \"store\": \"memberlist\"\n \"max_transfer_retries\": 0\n\"ingester_client\":\n \"grpc_client_config\":\n \"max_recv_msg_size\": 67108864\n \"remote_timeout\": \"1s\"\n\"limits_config\":\n \"enforce_metric_name\": false\n \"ingestion_burst_size_mb\": 20\n \"ingestion_rate_mb\": 10\n \"ingestion_rate_strategy\": \"global\"\n \"max_cache_freshness_per_query\": \"10m\"\n \"max_global_streams_per_user\": 10000\n \"max_query_length\": \"12000h\"\n \"max_query_parallelism\": 32\n \"max_streams_per_user\": 0\n \"reject_old_samples\": true\n \"reject_old_samples_max_age\": \"24h\"\n\"memberlist\":\n \"abort_if_cluster_join_fails\": false\n \"bind_port\": 7946\n \"join_members\":\n - \"observatorium-xyz-loki-gossip-ring.observatorium.svc.cluster.local:7946\"\n \"max_join_backoff\": \"1m\"\n \"max_join_retries\": 10\n \"min_join_backoff\": \"1s\"\n\"querier\":\n \"engine\":\n \"max_look_back_period\": \"5m\"\n \"timeout\": \"3m\"\n \"extra_query_delay\": \"0s\"\n \"query_ingesters_within\": \"2h\"\n \"query_timeout\": \"1h\"\n \"tail_max_duration\": \"1h\"\n\"query_range\":\n \"align_queries_with_step\": true\n \"cache_results\": true\n \"max_retries\": 5\n \"split_queries_by_interval\": \"30m\"\n\"schema_config\":\n \"configs\":\n - \"from\": \"2020-10-01\"\n \"index\":\n \"period\": \"24h\"\n \"prefix\": \"loki_index_\"\n \"object_store\": \"s3\"\n \"schema\": \"v11\"\n \"store\": \"boltdb-shipper\"\n\"server\":\n \"graceful_shutdown_timeout\": \"5s\"\n \"grpc_server_max_concurrent_streams\": 1000\n \"grpc_server_max_recv_msg_size\": 104857600\n \"grpc_server_max_send_msg_size\": 104857600\n \"http_listen_port\": 3100\n \"http_server_idle_timeout\": \"120s\"\n \"http_server_write_timeout\": \"1m\"\n\"storage_config\":\n \"boltdb_shipper\":\n \"active_index_directory\": \"/data/loki/index\"\n \"cache_location\": \"/data/loki/index_cache\"\n \"cache_ttl\": \"24h\"\n \"resync_interval\": \"5m\"\n \"shared_store\": \"s3\"","overrides.yaml":"{}"},"kind":"ConfigMap","metadata":{"annotations":{},"labels":{"app.kubernetes.io/instance":"observatorium-xyz","app.kubernetes.io/name":"loki","app.kubernetes.io/part-of":"observatorium","app.kubernetes.io/version":"2.2.0"},"name":"observatorium-xyz-loki","namespace":"observatorium"}}
creationTimestamp: "2021-08-12T11:34:10Z"
labels:
app.kubernetes.io/instance: observatorium-xyz
app.kubernetes.io/name: loki
app.kubernetes.io/part-of: observatorium
app.kubernetes.io/version: 2.2.0
managedFields:
- apiVersion: v1
fieldsType: FieldsV1
fieldsV1:
f:data:
f:config.yaml: {}
f:overrides.yaml: {}
f:metadata:
f:annotations:
f:kubectl.kubernetes.io/last-applied-configuration: {}
f:labels:
f:app.kubernetes.io/instance: {}
f:app.kubernetes.io/name: {}
f:app.kubernetes.io/part-of: {}
f:app.kubernetes.io/version: {}
manager: kubectl
operation: Update
time: "2021-08-12T11:34:10Z"
namespace: observatorium
resourceVersion: "8113011"
selfLink: /api/v1/namespaces/observatorium/configmaps/observatorium-xyz-loki
uid: bd9e8b22-f607-4065-b687-eea7448671f2
Could you send me any reference to fix these errors.
