Using Grafana10.4.1.
Want to be able to customize default notification alert messages inside of teams more like legacy one
- How are you trying to achieve it?
creating custom notification template
- What happened?
I’m getting empty message for this custom notification policy
that I get annotation message= “txt” -
{{ define "my.message" }}
Annotations:
{{ range .Annotations.SortedPairs }} - {{ .Name }} = {{ .Value }}
{{ end }}
{{ if gt (len .DashboardURL) 0 }} Go to Dashboard: [{{ .DashboardURL }}]({{ .DashboardURL }})
{{ end }}{{ if gt (len .PanelURL) 0 }}Go to Panel: [{{ .PanelURL }}]({{ .PanelURL }})
{{ end }}
{{ end }}
{{ define "my.title" }}
[{{ .Status | toUpper }}: {{ if eq .Status "firing" }}{{ .Alerts.Firing | len }}{{ else if eq .Status "resolved" }}{{.Alerts.Resolved | len }}{{ end }}] {{ .GroupLabels.SortedPairs.Values | join " " }}
{{ end }}
- Did you follow any online instructions? If so, what is the URL?
yes
