Embedding panel that forwards OAuth credentials
I have an application in which I’d like to embed Grafana panel. This panel uses the application itself as datasource through the simpod-json-datasource, forwarding the OAuth token. Application won’t provide any data without this token.
When using plain old <iframe /> the browser does not send Authorization header. Do I need to let the app act like a reverse proxy, too, adding the header? I’ve tried to set the iframe contents fetching it in Javascript but I’ve hit CORS and some other comments here suggest that I need a proxy to filter these from Grafana.
Before going that path (already too convoluted), will it work? Will Grafana use the correct user just after seeing the Authorization header?
Alternatively I can setup Grafana to use auth proxy, but can this one forward the OAuth token at the same time?
I’ve actually managed to get this working by disabling anonymous authentication and using the oauth_auto_login setting (I had a typo so it didn’t apply before).
EDIT: It doesn’t work 100% because the auth token is not refreshed; When escape the embedded panel and sign out, it logs me in again and works. But I need to make sure the token is refreshed.
EDIT2: Seems I am hitting this issue: https://github.com/grafana/grafana/issues/12131
