I have a problem using stat visualization with elastic search source. The main problem is - grafana doesn’t round decimals properly. This causes report errors because i need 100% fron theese 3 stat visualizations. The main problem with 18.2 - grafana rounds 18.25 to 18.2, how can i fix it? Can i write my own round query or something
can you try setting the decimals to 2?
Yeah, already did, but context of mine task requires only 1 decimal
