I installed the latest version of grafana using the installer.
Is it possible to modify the source code of grafana (for example grafana.json
in the path public/locales/en-US) and visualize its effects?
I have tried simply restarting the Grafana service but the result doesn’t change.
Hi @gaetanomele90,
Thanks for opening this post.
So, modifying the source code of the Grafana OSS version is totally fine.
It might be that the code which you modified needs to be loaded in a clear cache for the changes made in the localization part.
I tried editing the json, restarting grafana and clearing the browser cache.
But nothing has changed
