Dynamic add a new Dashboards for new cluster nodes
I am searching for a solution, that will allow my Grafana to dynamically add new Dashboards when a new cluster node or Kubernetes will arrive in my cluster.
I am gathering metrics via Prometheus. Is there any way to discover automagicaly any new node-exporter in the cluster?
Any tip or a pointed direction would be appreciated.
You can provision new dashboard using APIs as per you cluster creation process (check grafana provisionning).
Hope it helps.
Good Luck
